One box low
I have an 05CVR154 in 6ft^3 @20 Hz, 07CVR84 in 2ft^3 @40 Hz, and 07CVR84 in 2ft^3 at 61 Hz. It has good SQ and SPL is satsfying although sometimes I want more. I'm thinking about upgrading to L5, CVX, L7, or SWR. I think I can get away with changing the 15 without building a new box. I don't want to spend the time and would choose to stay with the current 15 if this box is wrong for an upgrade. This is not really my problem though.
The problem is the 60 Hz box has low output. I know the output is reduced below the tuning frequency so maybe there is no problem and I cut off the range that it works in. But the cone movement is small compared to the 40 Hz box. Is it the music I listen to that is not producing bass in this range (rap, house, metal)?
I think the current box design is fine since the other 2 have no problem. Both 8s are 200rms/400max, have voice coils wired in parallel, and are wired in series (correct me if I'm wrong = 4ohm load) to a Sony XM-D400P5 which has 400 rms/800 max @ 2ohms. I guess I'll try some bass tones and check the speaker to see if a wire came loose from the terminal.
All input is aprreciated on both the upgrade and the low output.
Umm.......IMHO just start over and sell all the subs you have.
Get 1 15" or 18" and build a box for that and tune it to about 35 hz and be done with it.
IDK how exactly you have all those setup but I think its not worth it.
ohearnjd
WTFO!!
ohearnjd
Los Angeles
roarzorz
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
