sdimeconcept
can I hook up this single sub to this 2 channel amp at 2 ohms?
The amp is a American Pro VS1405 2 Channel 2 x 130RMS at 2 ohms.
The sub is a 1022D TypeR. The wiring diagram shows that if you connect the neg to neg, pos to pos on the subwoofer, and then connect it to a bridged amp, it brings it down to 1 ohm. Is there a way to keep it at 2 ohms? Or will this amp even handle 1 ohm?
Thanks.
Thanks.
