old school rockford amp
bmk6795
i found an oldschool rockford 4channel on cl, wondering if it's worth picking up. really want toknow the specs on it if anyone recognizes it, any input is appreciated.
Not really old school. Also not really all that great to be total honest.
And no, that is not a 4 channel amplifier, it is a 2 channel as already stated.
ah yeah it's a 2ch. didn't really look at it, just read the description. Thanks for the input man.
yeah it says 201s
50 watts RMS x 2 at 4 ohms
100 watts RMS x 2 at 2 ohms
200 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
selectable Punch Bass (0/6/12 dB boost at 45 Hz)
speaker- and preamp-level inputs
10-1/8"W x 2-7/16"H x 9-7/8"D
50 watts RMS x 2 at 4 ohms100 watts RMS x 2 at 2 ohms
you think it's worth 50 bucks?
bmk6795
bmk6795
Spartanburg, SC
Jes 42
