Old School Power house for cheap! Audio Art 100HC
DARKHART
One Hitter Quitter
Audio Art 100HC
Not the prettiest but 100% functional. If you are looking at this then you already know what it is. Here we have one of the greatest old school "cheater" amps ever built. Built right here in the good ole USA, this amp rated at a modest 50w x 2 @ 4 ohms but this beast is stable down to 0.5ohm stereo or 1ohm bridged. Being a dual mono block design, the 100HC has two separate power supplies one for each channel that requires two separate power and ground inputs. She may not be the prettiest thing at the prom but come on, we all wanted the one that was going to "PUT OUT" after the prom and put out she does!!!!! Lol This amp was recently gone through by a certified mobile electronics repair tech to make sure that everything was as it was supposed to be and the amp checked out fine, if fact he noted that the amp was making about 105watts per channel at 4ohms on his test bench. This is a true 1100 watt + amp. Here's your chance to own a piece of car audio history that still performs just as well today as it did the day it came off the assembly line.
$180.00 Shipped in the CONUS
FREE SHIPPING
//content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif
Jes it is OBO //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
For those folks that are not running an active setup on their front stage this would be an amazing amp to run your entire front stage!!
They are excellent when it comes to SQ on mids and highs but can still deliver amazing clean sound on your sub stage!
DARKHART
One Hitter Quitter
DARKHART
LITTLE ROCK, AR
DARKHART
