I HAVE A 4 CHANNEL FOSGATE 851X AMP THIS THIS IS A POWER HOUSE AND CAN RUN ANYTHING YOU PUT TO IT, I RAN MY MID'S AND HIGH'S OFF OF THIS AMP FOR OVER A YEAR AND NEVER HAD ANY PROBLEMS HERE ARE THE SPEC'S
Details:
* 110 watts RMS x 4 at 4 ohms
* 215 watts RMS x 4 at 2 ohms
* 425 watts RMS x 2 in bridged mode at 4 ohms
* 2-, 3-, or 4-channel output
* 4-ohm stable in bridged mode
* Tri-way capable (Tri-Way crossover required)
* requires 4-gauge power and ground leads and a 60-amp fuse — wiring and hardware not included with amplifier
* MOSFET power supply and output devices
* front and rear 50-250 Hz high-pass/low-pass crossovers, 24 dB/octave slopes
* MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
* TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
* *****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
* NOMAD — advanced protection circuitry for "intelligent" shutdown protection
* wired remote control included for fingertip control of Punch Bass (for 0-18 dB of bass boost at 45 Hz)
* preamp-level (RCA) inputs
* preamp (RCA) outputs
* 17-1/16"W x 2-3/8"H x 9-7/8"D
Details:
