ok, need some assistance
mr.gaf
Ok, so I am still kind of getting the hang of Ohms and all of that crap. Anyway, I thought I'd hit you guys up since you likely know your stuff.
Amp details: Boss CX550 Chaos Exxtreme 800 Watts 2-Channel MOSFET Power Amplifier
MAX POWER, 2 OHM 400w x 2; RMS POWER, 4 OHM 125w x 2; MAX BRIDGED POWER, 4 OHM 800w x 1
SIGNAL-TO-NOISE RATIO 102 dB; THD 0.01%
DIMENSIONS: 11-7/8-InchW x 2-5/8-InchH x 12-3/16-InchL
Trimode operation; Bridgeable; Remote subwoofer level control; Line and speaker level inputs; Variable gain control
Power and protection LEDs; Variable lowpass and High pass crossovers; 0-+18dB variable bass boost; MOSFET power supply
Sub details: Kicker CompVR 07CVR102 10-Inch 2-Ohm DVC Subwoofer
10-inch CompVR Subwoofer with 2-ohm impedance
Injection-molded cone with 360-degree back bracing and aluminized coating; ribbed Santoprene surround
400 Watts RMS (800 Watts peak) power handling
25-500 Hz frequency response
One-year limited warranty
So do you think it'll work? If not then could you find some replacements for me please? Thanks in advance. I actually don't think that amp will work, I believe I'll need a 800 watt amp that does 400X2 at 4 ohms right?
I currently have a '99 Durango, and I am looking more for sounding good but still kind of loud at the same time, budget is around 250-300
I know it's important, however I must know what sub I want and therefore leading me to find the correct amp to power it before I can know dimensions my box must be.
Like a Bawss!
o.o lol alright, anyways i found a different sub, it's a kicker cvr10:
TWO NEW KICKER CVR10 COMPVR 10" 1600W 4-Ohm Car Audio Power Subwoofers
MAX Power Handling: 800 Watts per sub (1600 watts per pair)
RMS Power Handling: 400 Watts per sub (800 watts per pair)
Dual 4-Ohm Voice Coils
Progressive-Roll
Polycotton Spider for Imporved Linearity at High Volumes
Spiralead Tinsel Lead Technology
Polyimide High Temp Former
Dual High Temp Voice Coil Wire
Ribbed Santoprene Surround wit Improved Performance at High Excursion
Injection Molded Polypropylene Cone with Aluminized Coating
Constant Contact Back Bracing on Cone Eliminates Distortion
Stamped Steel Basket With Perimeter Venting
2 ohm 800 watt amp to 2 400 watt 4 ohm subs, should work right?
The only thing you will get it if you rush into this is a expensive
I only see 2 options if you are set on doing it with 300
1. Get on EBay and other sites with used gear. The stuff on here is probably too high end for your budget. But I have seen
2 12 inch kicker's as well as Alpine's in boxes with amps included for 250-300
2. Buy the JL w3 amp which is about a 100 and is the best sub in its price range easily. Also buy the box, do A Lot of research on it because its the most
Important aspect to how good the system will sound. Have some patience and get the amo next paycheck
whutdafcuk?! //content.invisioncic.com/y282845/emoticons/dont.gif.ed5870f9483b695f9745036963f41c24.gif
mr.gaf
mr.gaf
Shreveport, LA
rebelfromva
