OK need help!!!
are the dual 4ohm voice coil, OR old school single 4ohm voice coil, what modle number are the subs
your amp puts out 1500watts at 2ohms, IF u have two dual 4ohm subs, then u need to wire them to a 4ohm load, as this amp puts out 1000watts on a 4ohm load, it IS not 1 ohm stable so becareful on the wiring.
wire them like this
IF u have single 4 ohm subs it will place a 2 ohm load on your amp, and it will put out 1500watts, so be carefull settin your gain
wire them like this
give us the modle number so we can tell u for sure how to wire them
also as for box size and tuning. it seam that 2.5 cu ft per sub at 32Hz works well for the NEW type Rs, SOOOO 5 cu ft at 32 Hz would be ideal for them, also they can take more then the 500 watts there rated for (im asuming u have the new 05 and up type R) hopefully u have a dual 2ohm subs and can use your amp to is full potential
406er...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Type-R's do not come in SVC 4ohm configurations...if anything he has the dual 4.
Secondly, it would be an utter-waste th wire that zx1500 at 4 ohms. He would probably get somewhere in the nighborhood of 750W RMS and 375 per sub.
To the OP, Beef up your electrical with at least the big 3 in 1/0 and consider a small battery in the back and wire the subs to a final 1ohm on the kicker..
406er...
OOOPPPPPS your right, dual 2 and dual 4
i though the olds units had single 4ohm wich is what i wa refering too
Negative...I have the old ones //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif D2 and D4...
i stand corected
on the topic of the old ones, do u have a 10" u may wanna sell. it was sorta my first sub and i want another
xXLiMiT
xXLiMiT
ft worth,TX
xXLiMiT
