darkhunter139
Ok I decided I am going to upgrade my electrical. I will be running a diamond 800.1 amp at 800 watt (maybe 900 I think its under rated a bit) at 1 ohm
I have a honda accord with a 70 amp alt. I know I might be able to get away with stock electrical on that but I don't want to have to worry about it and I am probably going to upgrade eventually. I also am going to need to add a speaker amp so ill definitely need to upgrade after that.
Ok so I got a lot of questions here,
What upgrade should I do first?
I am going to do the big 3
Add an alternator (What size should I add?)
and maybe a battery (Will adding a battery be necessary?
I was looking at some alts on ebay and they seem to be priced pretty good (I have a 1994 accord)
Will I need to get this installed or is it easy to do yourself?
Thanks in advance!
Thanks in advance!
