Ohm wiring question
MikeP2389
Hey guys just found this site and i have to say it is really nice.
I have a question on how to wire my friends sub(s)
I know a pretty good amount of things when it comes to car audio but some of this stuff confuses me a bit.
My friend just got a hifonics bxi1606d mono amp and he just bought a 15" alpine type r(2ohm). Can someone tell me how to wire it to get a 2ohm load. I heard the type r's can take some overpowering so id like to push the 1100rms to it even though the max is 750-is it safe to do that?. can someone tell me or post up a diagram on how to wire it up to the amp to get that load? or should i run it at 4ohms?
In a couple more weeks hes going to be buying another type r and i would still like to run both at 2ohms. can someone also tell or post a diagram up on how to do that also?
thanks!
thanks!
the sub's, are the Dual 2 ohm/ 4ohm? single 2 ohm/ 4 ohm??
so basically until he gets the other dual voice coil 2ohm type r i have to run the one sub at 4ohms load and i cant do it at 2 right?
what about when he gets the other one cant i run em at a 2ohm load?
so basically until he gets the other dual voice coil 2ohm type r i have to run the one sub at 4ohms load and i cant do it at 2 right?what about when he gets the other one cant i run em at a 2ohm load?
yea run the one at 4 ohms, then when you get them both you can run the whole set up at 2 ohms. check out that rockford fosgate link i put up. you have a dual 2 ohm sub, then put in 1 or 2 subs itll give you your options.
check out http://www.teamnortheastspl.com for some shows, not many are booked yet but there will be in the spring/summer
MikeP2389
MikeP2389
Utica
MikeP2389
vegang
vegang
