Ohm Stable?
jrwalte
GA
I have a Phoenix Gold Ryval 8001 Amp.
I just lost one of my JL 8W3 6 ohm subs and was looking to temporarily wire my other 2 until I could replace the bad one with a new 8W3 v2.
I can wire for 6 ohm or 1.5 ohm.
My question is, will either of those possibly damage my amp? Am I better off not using my subs until I can replace the one so I can run them at 4 ohm?
Thanks.
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 600 watts x 1 channel
RMS Power (2 ohms) 800 watts x 1 channel
RMS Power (1 ohm) Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output 1600 watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 1%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 40 - 400 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 90 dB
Channel Separation N/A
Bass Boost 0 - 12 dB
Bass/Gain Remote Optional
Fan Cooled No
Fuse Rating 35A x 3
Thanks. That's what I'll do.
These subs are rated 125 RMS so the lowered power is no issue. In fact I'll be sure to keep the amp turned down so as not to accidentally damage these 2 that only need 250 watts RMS.
jrwalte
jrwalte
GA
jrwalte
Mike Mccabe
