ohm question
yours probably looks like this currently:
you could do it like this with the subs you have, and turn the gains up.
you'll need two Dual 2 ohm subs, each wired in series, then parallel to each other.
Dual 2 ohms subs = 4 ohms /each.
then parallel to each other = 2ohms.
your subs have 2 voice coils each. both are 4 ohms. wired in parallel that makes 2 ohms per sub. 2 subs parallel at 2 ohms each = 1 ohm.
you need dual 2 ohm subs, in series to get 2 ohms at the amp.
like this:
its wired like that
makaveli11
makaveli11
scarb
406er
NorthFramingham
    Jun 30, 2026
