efm80
what are all my ohm options for 2 dual voice coil 4 ohm subs? I can not seem to grasp the whole wiring and load science!! sorry
eddie
eddie
kinda what I thought. so for a 4 ohm load you would wire the subs in series to bring them to an 8 ohm load and then run them parallel to the amp to bring it down to 4 ohm. And for a 1 ohm load you would run the subs parallel to bring them to a 2 ohm load then run them both parallel to the amp to bring it down to a 1 ohm load. do I have all that right?????4 ohms and 1 ohm
see my post above for wiringkinda what I thought. so for a 4 ohm load you would wire the subs in series to bring them to an 8 ohm load and then run them parallel to the amp to bring it down to 4 ohm. And for a 1 ohm load you would run the subs parallel to bring them to a 2 ohm load then run them both parallel to the amp to bring it down to a 1 ohm load. do I have all that right?????
and if you had 2 single voice coil 3 ohm subs (w7's) what are your ohm options then??
thanks
