CRAZYCORNUTS18
Registered User
wut th diff between running 2 subs at 1 ohm and 4 ohm? i now its a noob question but plz help
Yeah I would defiantly watch that because if your amp isn't 1 ohm stable you could burn it up.If your amp is 1 Ohm stable it will likely put out significantly more power when shown a 1 Ohm load as opposed to a 4 Ohm load.
Generally that's the reason a substage is wired to a 1 Ohm load ~ to get the most available power from the amp driving it.
I'll assume from this post you are using a slash series JL amp?well my amp says 1.5-4 so it would better to put it at 4?
