Oh Yeah......oldschool MTX
blackMTXgold
PiMp MeMbEr
Alright well i have a MTX Black Gold 10" single 4ohm that was made in 1994, and i just got the specs from mtx on it..........pretty cool i thought
Nominal Impedance....4 ohms
RE (DC Resistance).....3.27 ohms
LEVC (Coil Inductance).....1.03 mH
SPLO (Reference Efficiency) @1W/1M.....87 dB
Frequency Response (+/-3dB)....... 17-2 kHz
FO (Free Air Resonance)...... 17Hz
QMS (Mechanical Q).....4.32
QES (Electrical Q)..... .34
QTS (Total Q)........ .31
BL (Force Factor)..... 7.3 N/A
Effective Piston Diameter.... 7.87 in.
VAS( Volume Acoustic Suspension)..... 9.04 cu. ft
XMAX (excursion)....... .36in
RMS........ 150 watts
Mounting Diameter.......... 9 1/4 in.
mounting Depth........ 4 9/16 in.
Speaker Displacement (inside box) 275 cu. In.
Speaker Displacement (Outside Box) 160 cu. in.
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
-38 oz Strontium Ferrite Magnet
-2" Thermally Conductive Black Kapton Voice Coil Former
-10" Molded and Treated Long Fiber Composite Cone
-Thermo-formed poly Dustcap
-Butyl Rubber Surround
-Perimeter and Pole Piece Cooling System
-Gold Plated Five-Way Binding Post
-Black Plated Top Plate, Bottom Plate and pole piece
the black and gold series was bad a**
I had the black and gold series 2300 amp rated at 150 x 2 or 600 x1 at 4 ohms. It was a nice amp and was pushing two HX2 15's hard....
blackMTXgold
PiMp MeMbEr
blackMTXgold
Waseca, MN
60_cent
