oh my god, do want.
you have a link to product page not seeing what makes them worth 1250
THIS UNIT MATERIAL IS TRADITIONAL KOREAN PAPER HANDMADE FROM MULBERRY TREES.
Because we know mulberry paper is FAR supperior to any other kind and adds 1200$ worth of SQ to a woofer that some 5 year old Korean kids are knocking out for 50$ a whack.
it's very hard to get specs and a website if you don't speak/read Korean
zoom.php
Mid-woofer HANJI654 (bullet)
HANJI 654-PS
■ 6.5 mid-woofer speakers
■ Sensitivity .......................... 91dB 91dB
■ 72~60kHz (-3DB) ■ frequency response band ........... 72 ~ 60kHz (-3DB)
■ DC .....................5.8ohm ■ DC Resistance ..................... 5.8ohm
■ ....................8 ohm ■ .................... 8 ohm impedance
■ ................200W ■ ................ 200W power handling
■ ................3.0 Khz ■ Crosspoint ................ 3.0 Khz
* Loudspeaker Measurement Systems * Loudspeaker Measurement Systems
* Electro Mech Speaker Parameters * Electro Mech Speaker Parameters
* Reference Curve = Sweep * Reference Curve = Sweep
* Delta M/C Curve = Sweep * Delta M / C Curve = Sweep
* Method = Double Curve - Delta Mass * Method = Double Curve - Delta Mass
* Domain = Free Air * Model = Standard * Domain = Free Air * Model = Standard
Revc = 5.800 Ohm Revc = 5.800 Ohm
Fo = 67.351Hz Fo = 67.351Hz
Sd = 12.272 sqM Vas = 13.99CUM Sd = 12.272 sqM Vas = 13.99CUM
Mms = 8.535g Mms = 8.535g
VC diameter = 39.6 mm VC diameter = 39.6 mm
VC hight = 14mm VC hight = 14mm
Qms = 1.568 Qms = 1.568
Qes = 0.312 Qes = 0.312
Qts = 0.261 Qts = 0.261
¼Ò³ë´ÙÀÎ ¼îÇθô Open
these in a rear loaded horn would be amazing sounding
---------- Post added at 05:18 PM ---------- Previous post was at 05:17 PM ----------
I also missed a word, I meant to say "Are you guys to stupid to realize what those are."
zoom.php
HANJI 654-PS
¼Ò³ë´ÙÀÎ ¼îÇθô Open
i see that they have extended freq response, but not much on the low end. i understand that the paper they use is probably extremely light weight and im sure it has a certain amount of strength, but i still don't see them being worth $1250 for just a mid range, if im going to pay that i can get the crossover mid-range and tweeter from focal (k2) series cheaper.
these arn't for cars. It drops off at 70hz with out an enclosure, which is where the horn comes in //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Focal k2's are garbage I know I owned them, Utopia or nothing.
I also never tried to pass them off as car speakers and said multiple times they weren't. There is plenty of **** on this website that isn't car audio, plenty in the same section as well.
wenn_du_weinst
wenn_du_weinst
Imtjnotu
michigan born
    May 14, 2026
michigan born
    May 14, 2026
