4 Headrest monitors................ are u mad!!!!!!!!!!
biglinton
Good evening and salutations, alright so i got an 2005 max se LOADED and i got a super deal on 4 headrest monitors now my question is since i never did this before is POWERING THEM can i wire them all together and route em to a fuse or some power source im a little lost also do u think i should get another battery i have my stock system just big rims and a 15 in the trunk with a JBL: GTO7001 running it
Appreciate the help!!!!!!!
hmmm... trying to figure out what you're asking exactly...
as far as the headrest monitors go, powering them... as long as you run a good sized gauge, you can run the power in line... but you will want to get a signal booster for the video signal, otherwise it will start to appear grainy.
as for the system... need a lil more info on that
just wondering wat everyone uses to power headrest monitors and can i wire them in line with each other thats all
you can wire the power, signal, and ground together on all of them, but as mast said you will need a video signal booster for the picture to come in clear.
biglinton
biglinton
saratoga, ny
kramer_212
michigan born
    May 14, 2026
michigan born
    May 14, 2026
