[OFFICIAL] Funny Craigslist Ads
Trade only 2audiobahn mono amps 4000 watts each looking for 5lug 5by114 wheels no smaller than 18 inch would really like 20 inch prefer Crome with good tires amps came out of boom audios competition van Nice shape text 607 321 7746
this boom audio place is the home of the most retrded car audio guy in the world, he says theres no such thing as a high output alt for gm vehicles, that 10s and 12s are tighter and 15 and 18s are sloppy and loud, he says that boxes dont matter and he says that audiobahn is the best **** ever made....he claims to be the loudest in the county with 2 audiobahn immortal 15s and 2 audiobahn 5000spl amps running on stock electrical, he says it hit 155.6 yet my single mojo 15 on 2k was louder.... explain that.
Here is another good one.......never knew Treo was made by JL....
12" Treo Sub, Box, RF Amp, RF Power Cap. Paid $775, Will Sell for $275 - $275 (Clearwater)
Date: 2011-05-20, 10:03PM EDT
Reply to: sale-n2nce-2393575888@craigslist.org [Errors when replying to ads?]
Selling my two 12" TREO Subs (made by JL Audio) with sealed box, ROCKFORD FOSGATE Punch 450.2 Amp and a ROCKFORD FOSGATE 1.0 Farad Power Capacitor. I paid $775 for everything new, and will sell altogether for only $275obo, that's a savings of $500. Everything is in absolutely mint condition and works great except for a tear I put in one of the subs when removing them from my old Lexus. So basically you need to replace one of the subs to use the same box, or remove the good one and put it in a single sub enclosure box. Regardless, a new RF Punch 450.2 amp alone would cost you $350 (without the good sub, box and power cap which I'm selling for $275), so my loss is your gain! If you would not like to purchase everything altogether for $275, then the following price per item is as follows: $125 for Amp. / $100 for 12" Sub. / $50 for Power Cap. / $60 for Box
TREO TE Series Sub Specs:
• Precision CNC-machined 220 oz. low-carbon steel motor structure
• Powerful and durable double-stacked strontium ferrite magnets with a protective rubber magnet boot
• Durable and attractive black oxide-treated motor structure
• High-flow large diameter pole vent
• High excursion motor structure and suspension design
• Tall extended displacement composite foam surround
• Resin-impregnated poly-cotton damper for increased cone control
• Integrated tinsel leads for increased reliability and enhanced sound quality at high excursion
• Mica-impregnated polypropylene hybrid cone with integrated dust cap
• Attractive anti-resonance Die-cast aluminum basket
• 2.5 inch high temperature Aluminum voice coils
• 500 Watts RMS power handling
• Dual 4 Ohm voice coils for increased installation flexibility
• Optimized for small sealed, vented and bandpass enclosures
Rockford Fosgate Punch 450.2 Amp Specs:
• Total Power: 450 Watts
• Rated Power: 100 W x 2 @ 4 Ohms RMS
• Rated Power: 225 W x 2 @ 2 Ohms RMS
• Rated Power: 450 W x 1 @ 4 Ohms bridged RMS
• Bridgeable
• 4 Gauge Power/Ground connections with built-in ATC fusing
• Aux Outputs
• Connector Cover
• Focused mass heatsink design
• Infrasonic filter
• Stealth Connections
• Thermal Sensing
• Top Mounted LED Indicators
• Crossover Controls: High-Pass (HP): 40-400Hz 12dB/octave Butterworth
• Crossover Controls: Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
• Tone Controls Bass: 0dB to +18dB @ 45Hz
• Signal Input Low level: 1 RCA pair
• Signal Output Low level: 1 RCA pair
• Power Input Connector: Block
• Power Wire Gauge: 4 AWG
• Speaker Output Connector: Screw terminal barrier strip
• Speaker Wire Gauge: 8 AWG to 18 AWG
• Cast aluminum Heat Sink
• Convection Cooling
• Visual Indicators: Power On, Signal Level, Thermal Status, Speaker Protection
• Class A/B Circuit
• Frequency Response: 20Hz to 20kHz +/- 0.5 dB
• Dimensions: 2.1 x 11 x 11.7 (in), 5.3 x 27.9 x 29.7 (cm)
• Weight 11 Lbs.
Rockford Fosgate 1.0 Farad Power Capacitor Specs:
• Improves sound quality - cleaner mids and highs / more powerful, longer bass
• Platinum plated
• Solid brass top helps reduce stripping
Please call ROB if interested, and leave a voicemail if I'm not able to answer my phone immediately. 727.692.7383
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2393575888
Made by JL... thats insulting
hardest hitting system 2 15 fosgate subwoofers - $1 (tampa fl)
Date: 2011-06-12, 2:17PM EDT
Reply to: sale-8xv9x-2436124462@craigslist.org [Errors when replying to ads?]
2 15in fosgate P2 subwoofers TOP BRAND SUBS 400
1800w kenwood amp for 200
hardest system ive ever own
serious top of the line system
serious buyers only
set your price but no lowballing
email me
Now this is funny, send him a message....
Killer System for sale!!!!!!!!!! - $650 (St.Petersburg)
Date: 2011-06-13, 1:03PM EDT
Reply to: sale-kuvud-2437848395@craigslist.org [Errors when replying to ads?]
Im trying to get rid of my system dont have any use for it. i have three 12'' excursion subs in a imported box with a 1200 watt amp. It really loud and powerful. i wanna get rid of it asap so if ur interested ,have questions or u wanna see it and hear it give me a call or text me at 727 729 0226.
  • it's ok to contact this poster with services or other commercial interests
PostingID: 2437848395
Wow...
Now this if funny......
Speakers Subs, box.. 2, 12s,Brand New - $75 (Tampa)
Date: 2011-07-03, 10:33AM EDT
Reply to: sale-dra7u-2428310765@craigslist.org [Errors when replying to ads?]
I have a professional competion box I built for a customer. The box is tuned at 40 Herzts and sound amazing!!!!!!! Hits very hard. The box has never been installed in a car just hooked up to tune the box to the speakers. The box did a 150 spl on the dash just testing the box so it should hit about 3 bds or so lounder when the speakers get broken in. The speakers are brand new with a warranty.. Amp does not come with it. First $75 cash gets it all.
First $75 obo cash gets it all.
Call 813-401-3169
i have two 12 inch kicker comp vrs sealed in a new qlogic box pound really loud i won alot of competions with these subs
Selling my S10's set up unfortunately, due to buying a new vehicle and selling my current, this Set up will not fit in my new car!The reason im selling cheap is because I need the money asap.
This is by far one of the loudest set ups in Oveido.
System includes; (pictures at bottom)
1 18" FI BTL Fully loaded subwoofer (loudest on the market)
1 Professionally built SPL L-Port 38hz ported box (ment to be extremely loud but still has top tier sound quality)
1 MA audio HK4000 Amplifier (4000 rms)
4 Brand new 1000ca Redtop batteries
All the wiring you will need to set everything up ( including; fuses, fuses panels, about 15 feet of brand new zero gauge wire)
2 Kenwood Excellon 6x9 350 watt speakers Inside 2 separate small enclosures (not shown in picture)
The box is 7.5 cubic feet and fits perfectly in a extended cab s10, and pretty much anything suv related as well. (text for exact measurements)
If you live in the Oviedo area you have most likely heard this system before (Orange custom S10), and understand just how loud it is
On a SPL meter I hit a 151db without my new batteries, so its even louder now.
DO NOT be fooled by its insane nature and think this speaker doesnt have quality, because its huge quality made voice coil delivers the absolute best sound quality and is stable down to about 12hz!
You can also run this sub at 4000 watts (gain all the way up) for short periods because its made to have up to 10000+ burped on it so it can handle 4000 easy
I drive with gain at 1/2 and rarely turn it up higher just because its impossible to see the road with it higher.
If you have any questions or are interested please text me at (Four Zero Seven)-451-6477
Bold made me lol
We have a pyle car stereo dvd bluetooth enabled gps enabled 7in. screen remote control also a 3000 watt quantum cozmik series amp also a 15in quantum subwoofer also the amp wire with 60w fuses im willing to let everything go for 500.00 brand new never been used call claudia at 3614846186
ha
Wow...
those hollywood sound labs are decent subs. should be around 300$ for the subs total. I liked mine.
Seems everyone is infatuated with CL so instead of making 2.3 million threads post your funny craigslist posts here. Make sure you post a screenshot of the ad as well as the contents. Craigslist links expire fairly quickly and nobody wants to sift through them.
Any posts from 5/20/2011 and later will be deleted if the rules cant be followed. This is a trail run so make it count.
Seriously guys!!!!
Hmm.....275 for a box and sub that can be had new for less then 200....
JL AUDIO DIGITAL AMP AND SUB
Date: 2011-07-17, 10:42AM EDT
Reply to: see below [Errors when replying to ads?]
JL AUDIO XD600 DIGITAL AMP, 12w0 SUB IN BOX, STINGER WIRES- $625 FOR ALL.... WILLING TO SELL SEPARATE AMP-$350 SUB-$275 COME GET TODAY!!!!!! TXT OR CALL ANYTIME (203)565-9462
PostingID: 2490247076
Hey, the ad says call any time...
Both are great quality.......
2 subs for sale - $90 (Midland)
Date: 2011-07-16, 4:32AM EDT
Reply to: sale-wkymc-2496902333@craigslist.org [Errors when replying to ads?]
hey everyone i got two subs for sale.. i got a dhd 15" and a lanzar 10" both are great quality. My family is PCSing and i have no room in my car to hold them for the summer.. the 15" is a $60 also in a ported box and the 10" is $30.. text or emails only.. please no calling.,.. if you send an email put in the header "SUB FOR SALE" in caps so i know it is not spam.. Thanks :)
I will think about all offers. i need sold by sunday so please give me all offers because by sunday the highest offer will get it!
whitedragon551
Moderator
whitedragon551
IL
CertifiedHoodClassic
