Official CarAudio.com Big 3 Thread
Well he told me that the way some alternators are wired that it wont work because you cant change it. I take the words of you hundreds to the fact it works but is it a universal modification or is there alternators you cant do it to
. what year and car do you have?
engine to battery neg + chassis to battery neg = chassis to engine
why does no one understand that?
Was just gonna ask is that why there is 2 wires hooked up to my negative? Since ill be putting 1/0 awg whats the best way to connect it to the battery, some sort of terminal cause im also gonna need space to hook up an extra battery
you should have 3 neg wires at the battery.
1. stock wire
2. engine ground
3. chassis ground
4. IF YOU GROUNDED REAR BATTERY TO FRONT BATTERY
you should have 3 on the positive side at the battery
1. stock wire
2. alt to battery
3. run to the amp. (or rear battery)
am i missing something?
1. stock wire
2. engine ground
3. chassis ground
1. stock wire
2. alt to battery
Is this after I'm done the Big3? And my grounded rear to front you mean connect them in parallel/series.
And wait, do I leave the stock cable there? I thought I need to replace them, or am I just adding on more?
thats after battery and big 3. i'd leave the stock wire, as it may go to a fuse box somewhere. some people take them out though.
and the battery should be in parallel (+ to +, - to -)
johnecon2001
SSA/ROE Super-Møderator
johnecon2001
Phoenix, AZ
2023 LTZ
