OEM head unit interface units
Controlit
I have 2011 super duty with sync and want to keep my factory head unit only because I like all the controls,bt steaming and commands ect...What do you guys think is a good interface unit like PAC,Control Audio,JL Audio's unit ect.. I will be running sub,amps,new speakers threw out if and when I decide on them.LOL
It should depend on what your installer knows. I would use the JBL MS-8 processor to do the job of integrating into the factory amplifier. It has an internal amplifier that can be used to power up to 8 speakers directly.
Where do you live?
Where do you live?
How does the MS-8 compare to the Audison bit ten?
It has auto-EQ, which is a HUGE feature, it supports more channels, it has a built-in 8-channel amplifier if you need it, it has Logic 7 for focusing the sound depending on the seating positions(this does require a center channel speaker setup to work this way).
Controlit
Controlit
Central,ND
trumpet
Mike Mccabe
