you should be fine with the stock electrical on the brz1200 on stock electrical.Will wiring them at 1 ohm put more stress on my electrical system? (Stock alt and batt )
what size alt do you have by the way? also to help out id just grab a extra battery to go in back by the amp to help out some if you drop voltage to muchWill wiring them at 1 ohm put more stress on my electrical system? (Stock alt and batt )
that would be my bad i thought i read 2 "zv3" 12s lol. my badI think there is a slight miss communication. I meant 2 Obsidian 12" v3. ( Obsidian Car Audio ) With that being said will the light dim or anything like that? And will a 4 cb ft ported box get the job done?
I honestly don't know. 1 last question. If I were to get 2 15 Obsidians what kind of amp would I need and would that one cause any electrical probs? Thanks!you should be fine with the stock electrical on the brz1200 on stock electrical.
---------- Post added at 08:56 PM ---------- Previous post was at 08:55 PM ----------
the whole line of obsidian's are rated 600 rms so you could get the same amp and be goodI honestly don't know. 1 last question. If I were to get 2 15 Obsidians what kind of amp would I need and would that one cause any electrical probs? Thanks!
You are pushing it on room for 2 15's man. I would do two 12's in the proper enclosure and call it a day. If you have never had a system this setup will blow you away. You might shoehorn the 15' in there but the box will be so large you will be choking off your output.I honestly don't know. 1 last question. If I were to get 2 15 Obsidians what kind of amp would I need and would that one cause any electrical probs? Thanks!
Ya that was a worry for me, so Ill just go with the 12's .Thanks!You are pushing it on room for 2 15's man. I would do two 12's in the proper enclosure and call it a day. If you have never had a system this setup will blow you away. You might shoehorn the 15' in there but the box will be so large you will be choking off your output.
Go with the 12s they will perform better than the 15s bc they will be in the right size box ..15s would have to have a box built in the trunk more than likely.as far as amp or electrical..id get a amp that does 1500-1800 rns ..the ppi bk1800 as suggested is a good amp for 199 bucks ...u will need to look at doing the big 3 and replacing the battery under the hood with a agm ...then monitor voltage drop and decide if you need a secondary battery..also make sure u get a custom box designed or built to make them shine ..a prefab box will not do those oa.s any justiceYa that was a worry for me, so Ill just go with the 12's .Thanks!
what If I only did the big 3. Would that give me the power I need?Go with the 12s they will perform better than the 15s bc they will be in the right size box ..15s would have to have a box built in the trunk more than likely.as far as amp or electrical..id get a amp that does 1500-1800 rns ..the ppi bk1800 as suggested is a good amp for 199 bucks ...u will need to look at doing the big 3 and replacing the battery under the hood with a agm ...then monitor voltage drop and decide if you need a secondary battery..also make sure u get a custom box designed or built to make them shine ..a prefab box will not do those oa.s any justice
Ur gona run into issueswhat If I only did the big 3. Would that give me the power I need?
