Numbers are weird or I'm retarded.
I redid the port measurements...the original ones were the speaker manufacturers specs. A little editing, I got .7 cubic ft box, 1.5x12" port with 53.83 inches in length. Why is it when I make the port narrower, the length gets shorter?
because the lower sq in of port area, the shorter port you need for the same tuning, its basic box design
ps a .7 cubic ft PORTED box is tiny, i hope its for an 8 or somethin, and even then thats too small
It's for a 10, but I am looking to create a flatter response. when I increase the box size, I get a huge discrepancy with a difference of 6 db's both ways at whatever frequency I set it at. But when I decreased the size of the box, I got the balance back. I know this makes the box abnormally small for a ported box, but I am willing to risk it unless someone can talk me out of it.
If you want a flat response, you want a larger, ESB style box tuned really low. Smaller boxes are for tuning higher and being boomy at a very specific frequency for SPL purposes. If you want a super flat response, get something like 1.5 cubes with the port volume already subtracted and go for like 25 square inches of port area. For example, a port that is 2 inches wide and 12 inches tall would be 24 sq. in of port area and would be fine for a 10, large enough to not get port noise. Then you make the port longer or shorter length wise to set the tuning. Just use the RE Box calculator if you're going for a simple slot-port design. You can tweak each aspect of the box and it'll even give you a cut-sheet to build the box with.
Best of luck //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What is an ESB style box? (noob)
Sorry, mis-typed that. I meant "EBS".
EBS boxes are purposely built larger and lower tuned than recommended. This makes for a box that doesn't have any extremely high peaks at certain frequencies. It keeps a very even response at most frequencies with really really good low end extension.
These boxes are pretty big though, you've gotta have some space to spare.
If you were originally planning to do like a single 12" in say 1.5-2 cubic feet, and EBS box would be like 2.5 cubic feet tuned under 25 Hz.
Thanks, you just clarified 10 hours of looking at my computer in 20 minutes.
so what do you think of BassBoxPro 6 DNick454 ??ive tried winisd and never had good results.
I'd say the easiest, and most accurate, box calc's are the ones offered by RE Audio and the one on http://www.bcae1.com
The easiest is the RE Audio one, but that only for slot ports. The bcae one you can adjust for all different sizes and dimensions for ports including round ports but you need to know a little more information. The bcae one also can't do curved ports, so you have to do some figuring out on your own there.
EDIT: If you're looking for the one on bcae1.com It can be a bit hard to find, it is a rather large database. There is the main page for viewing, then there is like a little tiny scroll-down page on the right with the directory of information. The one you are looking for with all the box building calculators is number 110. It's a ways down. Good luck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
soldiermedic
Noob4Life
soldiermedic
San Antonio, Texas
DNick454
