Nsb 100
I have a nsb125 and its ridiculous....not even close to the 2400 imo
But not for daily....your alt wouldn't be able to charge it fully....if you got the time to give it a good charge once a week than ur good
you serious? you can play 4000wrms off your battery for a week with just the alternator charging, before its low enough to force you to charge it with a stand alone unit?
edit: whoops, thought you were currently running the mm4000
Whats it compare to?
I know that they are good.
Maybe compared to a hc2400.... hows it stack up?
I have never used NSB, I am getting one to try in my new setup...
But I would see how they compared to other batteries..
Note: Daily use with 300-500 amp draw at the very most.
The NSB100 would walk over the Kinetik for burps. But it will get weaker and weaker from daily use.
edit: Skip01 said it best //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how often do you recommend it being charged?
Well at least once a week over night would be good if it were me....or 2 times a week would be even better.
another thing...
whats the best way to go about "training" a battery (eg NSB 100FT) to float at 13v or higher?
Well right now ive been chargin it for a while, it was at like 12.8 and i had it on a 14.8ish charge for like 3 days and its just now at 13.0 resting
If you have the time and patience....get a 30amo/2amp and keep cycling it...go up to 15.5 than down to 13ish and back and forth for a while...that seems to work best but im just gonna keep this charge on for a few more hours than see what happens
Good Luck....and yours may have better results i believe mine is a lil bigger...119lbs...hate loading this ***** especially with no cute like braided straps like kinetik haha:p:
xtremebassjunky
Is it ever loud enough?
xtremebassjunky
Charleston, SC, (Oklahoma)
Skip01
NorthFramingham
    Jun 30, 2026
