Now Hiring: Enclosure Designer
theCybe
sector three
Hi.
Looking for an enclosure designer that knows their stuff to design an enclosure for two eight-inch soundsplinter prototype woofers.
AIM: SoundSplinter
AIM: theCybe
Thanks,
Blake.
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Qts - 0.405
Qes - 0.442
Qms - 4.778
Fs - 34.289 Hz
Re - 5.25 Ohm
Ls - 12.16mH
Lp - 4.053 mH
Rp - 25.46 Ohm
Sd - 0.020 m^2
Vas - 5.031 L
Mms - 214.1 g
Cms - 100.6 m/N
Bl - 23.39 T*m
Sensitivity - 78.44 dB
Yep, SVC 6 ohms.
I will post something up a little later tonight.
Could you please define your goal with this setup again.
I know it was 41" wide and needs to be as small as possible the other two dimensions.
Also whats the depth on the subs and displacement. If you dotn have displacement get some measurements and I will just calculate it. Should be able to get it close enough...
theCybe
sector three
theCybe
Columbus, OH
iamamp3pimp
