Novice needs solid Advice
chrish
Hello, fist time poster here. I recently bought a pionner Gm d8604 4 ch amp as well as salvaging some kappa 682.7cf speakers (2 ohm each) 1 pair as well as 4 alpine sps-517 6x8 (4 ohm Each) 2 pair with a alpine cde-143bt Head unit out of a trashed suv. how would you guys set this system up? what speakers can i use? any advice would be Awsome. do not want to set my wifes car on fire wiring the kappas to this amp. also if I can use the 2 ohm kappas how should they be wired? series or parralel? idont understand what im totally doing and just need some solid advice. right now i have it set up with all the alpine speakers. i was wanting to wire 2 alpines up front and the two kappas in back. is this possable with this mentioned set up??
If I were you I purchase a new headunit with 4 ohm speaker u can use the 2 ohm and wire in series but u need to see what your amp rating are you should use the 6x8 in the back if it fit.
Sent from my SM-T330NU using Tapatalk
chrish
chrish
oroville Ca
imiguenes
