Nothings working anymore...just power to cd player
  • 2
dirtbagz89
dirtyTHIRTY
Hey, it's been a while since I've been on here and a couple years since I made installs so I've come a little out of touch with everything. So here's the issue... this morning I drove to work CD player worked fine...amp worked fine...sub worked fine.
At lunch time I leave to get food.. cd player powers but nothing is on the display, no sound, etc....amp doesn't work, and of course sub doesn't work. The ring around the volume knob on the cd player is the only think working. (it lights)
I've checked all of my connections and everything looks fine.
Help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Humm...well I assume you tried hitting your source button a few times to see what the deal is...reason your subs aren't working is because the HU isn't sending any signal to the amp because its jacked up. Is it a flip face? try rubbing alchole on the connection to see if the faceplate just isnt making a good connection...What type of vehicle is it in? was it installed using wire harness or hardwired?
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
dirtbagz89
dirtyTHIRTY
dirtbagz89
Buffalo, New York, United States
dirtbagz89
