Starting bid will be 100 dollars for it or a dvd/ and or Nav. Flip out or double din.
I dont need a name brand headunit but w/e
The Amp Is grounding out.. Possibly the rca's grounding out. Easy/Cheap to have repaired
I bought this amp 2-3 months ago at Full Msrp ($500) //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif I was stupid.
Specs
2000wrms @ 1ohm
1300wrms @ 2ohm
650wrms @ 4ohms
# Protection: DC, Speaker Short, Thermal, Overload
# Power Supply MOSFET
# Audio Output MOSFET
# Dampening Factor: >250
# Signal To Noise Ratio (A-weighted): >95dB
# Variable Input Level Control (unbalanced): 0.2V - 9V
# Input Level Control (balanced): 0.04V - 18V
# Input Impedance (un-balanced): 47k-Ohm
# Input Impedance (balanced): 20k-Ohm
# Power / Diagnostic L.E.D.
# Variable Low Pass Filter / 24dB: 35Hz - 250Hz
# Variable Subsonic Filter / 24dB: 15Hz - 35Hz
# Variable Bass EQ: 0dB - +10dB
# Phase Shift (0 - +180 degrees)
# Unbalanced Inputs (RCA)
# Balanced Inputs (DIN)
# Line Output (RCA)
# Speaker Terminals (molded): 12ga
# Power/Ground Terminals (molded): 0ga
# Remote Bass Module: HFR-3
# Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
# Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
# Balanced line input for MX accessories and line drivers
# Bass Remote included
# Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Specs
2000wrms @ 1ohm
1300wrms @ 2ohm
650wrms @ 4ohms
# Line Output (RCA)
