not handling 1 ohm load?
Relax
MN
hifonics bx1500d at 1 ohm load loosing volume and cutting out at higher volumes. I have the big 3 upped to 2/0. All else is stock elec. Suzuki Verona 05. I'm guessing the stock alternater needs upgrading? or i need to replace the amp with something that can handle the 1 ohm load better??
that amp should do 1 ohm np... I ran one at .5 on a custom solo x 12 in my celica for a while, barely ever cut off, though I wouldn't recommend it.
what batt you running? i'd start there and upgrade it.
i'm not even really pushing the amp very hard. 1 ohm load into 2x 500rms p3's. gain at 2/3, sub zone s%#$ and boost all at zero. lights not dimming.
never up'd an alt before. any tips on how to buy the right alt to fit my car?? or does it matter? probably 150 amps?
i have that amp on all stock electrical, 4ga power/ground at 1ohm with gain right around 2/3 and it has never cut out or even got hot for that matter. My stock alt is 102 amp...i do however get dimming lights.
redid the grounds a couple of weeks ago, nothing changed. i pulled everything out(pain in the a$$), made sure of the wiring/ohmage. 2 d4 subs ran in parallel to 1 ohm. New amp?? That amp has been in my possession for about 7 years.
I just have a gut feeling that it's the amp that needs the replacing/fixing considering that the lights don't dim at all and i'm not getting the power i used to...and nothing changed after i upgraded the big 3.
Hey kr15, finding some pretty good prices (under 200) on the bxi1508d. Any complaints with it? I want something that takes 4ga and puts out rated at 1 ohm. That amp might not be a bad idea...i'd like a discus but don't want to up to 1/0.
Relax
Relax
MN
kr15
