not a newb but need opinions
CAT MAN
Banned
looking at some amps. my selection has changed. i was going to do a brz2400 until i found out i would be out of my most competitive class. so ive been looking at the AP 1500 16v version. or thee regular for that matter. anyone used these. and is a brz1700 really that much betteR?
can these get into the mid 40sdb range?
and what true abuse/power can they put out.
i have a rxd2400.1 for sale
2400 @ 1 ohm
1600 @ 2
1000 @ 4
i had finals sunday. i did a 143 @ head rest due to it was turned down. i oscoped & fixed my db numbers after i ran lol.
i usually do a 45+ at headrest
oh yea you wrote me earlyr. i gota fix the pics when i get home
---------- Post added at 02:28 PM ---------- Previous post was at 02:28 PM ----------
how would it put you out of class?
had a txi7506 . and amps do produce DB's if you want to get technical lol. but i know what you mean.
and the class is 0-600(4 ohm power) trunk street. ill have 2 batts from ram designs(bat cap look alikes) so electrical will be stable for 2.5k.
need some kind of power that will impress on a budget too if i can squeeeze that in
just to get technical even though off topic, please elaborate how a amp produces DB's. not to power the woofer to giv off decibels, but how does the amp itself produce db's.
back to topic, there are some treo amps that are rated low at 4ohm but put out massive power at .5 ohm. what woofers are you using?
---------- Post added at 12:15 PM ---------- Previous post was at 12:14 PM ----------
mines does 1000 @ 4ohm
he needs 600 @ 4 bro
amps make power. power goes to subs. that = dbs..
subs are bxi 12s from hifonics, not much specs but the coil is 3'' motor is a beast. its the big brother of the bx line pretty much. they can do 1500 on burps 1k daily.
only can get a 1 ohm load. they are D4 sorry
CAT MAN
Banned
CAT MAN
Roanoke,VA
CAT MAN
