Noobish question - blown sub?
low00ranger
I've been playing with DD 1008's in my truck... installed 3 ported with a Brutus 1606d almost 2 years ago and beat the hell out of it for a year or so before I stopped driving my truck and never had a problem. I got a 4th 1008 used a few months back and just this last week got around to building a new box for the 4 8s, still using the 1606d. The 4th sub looked fine visually and read 4 ohms. Got it all in tonite and went driving for a good listen.
1 Jeezy song with higher bass and it sounds great. Go to a classic Bass Mekanik song with lower bass and it sounds phenomal for 20 secs and output goes way way down. It suddenly sounds like someone punching a paper sack. So I turn it down real fast, smell around - no bad smells. I turn it up so I can barely hear it a couple times and make sure it still sounds like crap. When I get home I shut it all down and get the DMM to check resistance across the speaker outputs, it reads 1 ohm perfectly. So the amps not hot and everything looks to be in place, is it possible one of the subs(the newest one I never used) is blown? I usually hear that when subs are blown the resistance will be way off but that's not the case for the overall series and I never smelled anything bad. Maybe the spider got disconnected from the basket on one of the subs?
If you have a fuse at battery up front, check to see if it is not blown. The exact same thing happened to me 2 weeks ago and it was a blown fuse up by front battery.
Well I checked that this morning and the fuse looked good to me. I was hoping that was the problem but it doesn't look like it.
you could remove each speaker and give each speaker a test. it could be the amp itself.
if the noise was coming from all the speakers then it is possible that your amp just took a dump on you.
I plan on doing that tonight. I just hope I can narrow it down because I have very little experience with blown equipment. Its going to **** if the 4th sub is blown that I bought used here in August but never hooked up until now.
I say lower bass but it wasn't that low. Probably high 30s or 40 even, my box is tuned to 37 Hz. I can tell when the subs are bottoming out and I pretty much know what songs to avoid - I ran a trio of these for at least a year with the same tuning without issue. I don't think I messed up anything by playing too low of a frequency.
I really couldn't tell if the sound was coming from one or all subs. I put my ear next to each sub with subs still in the box and couldn't single out any one sub. I'll just have to pull them out tonight. I hate pulling out //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
I'm running a 150A ANL fuse over 0 gauge wire. The 1606 has 2 70A fuses and I run an Infinity 200w amp for my mids and highs. I have a spare 150A and a 200A fuse for my alt I can throw in just to confirm/eliminate that piece.
This may be getting too far ahead but what all would be involved with fixing a vc/cone separation? I'm sure I could get it fixed with DD but these subs are only worth about 100 each used and they're not made anymore. Maybe I could give it a shot myself or send it to someone here who is good with woofer repairs.
low00ranger
low00ranger
USA
low00ranger
