noob question
Basically you just need an amp that is going to give you the rated power of the subs at the load that it requires.
So a dual channel amp, bridged, or a mono will work. Just as long as you don't over-power the subs.
If it all comes to one speaker terminal, then you will have no issues.
If there is a speaker plug for each speaker, you may need to rewire. The only thing you really DO NOT want to do is run a 2 channel with each channel going to a sub.
b0b0washere
b0b0washere
b0b0washere
NH
Pl8er
