Noob Needs Help
theseusc1
I have a 2012 Kia Rio and am running an MTX 10" powered sub. There were no RCA jacks on the head unit, so I ran a line output converter to the left rear door. I ran the remote wire to an accessory fuse and tapped it. I grounded it appropriately to a metal screw against non-painted metal chassis. I used 8 gauge wiring for the power and ran that to a fuse block and then to the battery. Just trying to eliminate some unnecessary questions about my setup. Now to the question: The bass will come on intermittently. I will say more times then not, but usually there's a delay involved. Oh and yes, the remotes is connected to a 12 amp fuse. The second question: My amp tipped and pulled the crimp ring off the power wire. No problem, I just fanned out the copper and screwed it back on without. Within a day, my car was dead. No lights or additional power sources were left on either. Also my key transmitter would no longer work? Not thinking the two were related, I got a jump, it fired up immediately, and I went to get the battery checked out. The battery was perfect, as were the cables. Next day, car dead again. That night, unplugged the power from the amp. 2 days later, car still holding a charge and starting with no problem AND the transmitter on my key started working again. What...the...hell???
The REMOTE input on the amp needs to be connected to a *switched* power source. Otherwise the amp is on all the time (even when car is off). Is the amp's REMOTE input connected to a switched source?
It would help us help you if you told us the exact make/model LOC and make/model amp you are using.
Yes, it's connected to a "switched" source. As for the make and model, I opened with that in the beginning of my post. "I have a 2012 Kia Rio and am running an MTX XT110P" powered sub. What else can I tell you about the make and model of either that will help you, help me, please?
Thanks
So what should I see/be looking for in output, the ampage? What's the normal range, or is it particular to the amp's specs?
Thanks for your suggestion!
Turn "Auto-Sense" off.
The MTX is trying to sum all the inputs - while it should work with only one channel, it will work best if you can connect both left and right front inputs.
Better yet, connect all four (front r/l & rear r/l)
(EDIT - sorry, missed that you are using LOC)
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
971
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
theseusc1
theseusc1
Olathe, KS
theseusc1
    May 16, 2024
    May 16, 2024
