Item stays in protect mode. I got a quote to fix this item and it takes a 100 bucks to do so. This amp is underrated so you'll be getting plenty of power for mids and tweeters when it's fixed. Asking $105 shipped. My feedback is 100% out of 100 transactions. My ebay account is ent3rdadragon. Pictures will be up in a bit.
Features:
Fully regulated MOSFET power supplies
PWM circuitry
Tri-guard amplifier protection
IDI ¢â(Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
Platinum RCA inputs and outputs
Bi-linear selectable crossovers for inputs and outputs (Hi / Full / Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180¡Æ)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
Optional Remote Bass Control (EGA-RM)
SPECIFICATIONS
No. OF CHANNELS : 4
OUTPUT(Watts) : RMS @ 4-ohms : 110 x 4
RMS @ 2-ohms : 220 x 4
RMS @ 4-ohm Mono : 440 x 2
THD: 0.02 %
FREQ. RESPONSE(Hz) : 10 - 30 k
S/N RATIO : > 97dB
DAMPING FACTOR : > 200
INPUT SENSITIVITY : 200mV
CROSSOVER SLOPES : 12dB
CROSSOVER FREQS : High-Pass (Hz) : 50 - 600
Low-Pass (Hz) :
50 - 150
SUBWOOFER EQ : 0 - 18dB
SUBWOOFER EQ FREQ. (Hz) : 40 - 120
DIMENSIONS (INCHES) : 11" x 2.2" x 17.7"
Features:
PWM circuitry
Tri-mode operation
SPECIFICATIONS
No. OF CHANNELS : 4
THD: 0.02 %
S/N RATIO : > 97dB
Low-Pass (Hz) :
50 - 150
