Noisy HO Alternator?
njknittle
PA
Got the Excessive Amperage 200a Alternator in for my Fiesta, everything hooked up right. And when i started it, it seems to have a wine to it, and a smell. The smell went away cause im assuming its new, "that new alternator smell." But the noise is only loud when its not under load. Are all HO typically noisier than factory Alts?
Belt slipping? I had to drop it down a few sizes, it would slip under load even though i thought it was tight
No, idts, the belt is tighter than a frogs *******. And i said it was only loud when its not under a load, only at idle. It sounds normally fine when under load
My alt whines, kind of sounds like a jet. 300 amp EA alt.
---------- Post added at 01:47 PM ---------- Previous post was at 01:47 PM ----------
And not alt whine through the speakers, just the actual alt itself.
doesn't matter how tight the belt is, it can still slip
What do i do to prevent that if thats the case?
---------- Post added at 11:11 AM ---------- Previous post was at 11:11 AM ----------
If you say tighten it, than your contradicting yourself.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
It's a new alternator? On mine the pulley is "glazed", it's gotten really smooth and shiny to where the belt won't grab it. I need to get a new pulley
sounds like the noise yours is making could be normal. I was thinking slip because of the smell. I never noticed a smell on mine, but when the alt is under load and it slips you can smell the rubber burning lol
njknittle
njknittle
PA
njknittle
