Noise with engine running!!!
  • 2
Cherrykee
Ok I have two 15 inch kicker L7 solobarics and two hifonics 1600 watt amps. I have a dual flip out touchscreen dvd player as my head unit. I am running 2 gauge power wire and two 1 farad capacitors. the ground wire is 4 gauge and running to under the rear seat bolted down to a metal lip piece. Im thinkn i need a better ground. when the truck is off it doesnt make a noise but as soon as i start it it hums with the engine and hits a little when i open the door or try starting the vehicle while the system is on. HELP!!!
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Cherrykee
Cherrykee
illinois
misfit138
    May 18, 2024
    May 18, 2024
