noise through speakers
coleg
ga
I've tried to find something similar to my problem, but was not successful. I have an infinity 4 channel amp powering 4 6x9's. When I plug 2 channels in (Pioneer) head unit there is no alt noise or hum. When I plug the other 2 in, all 4 of them make noise. I also used an old 2 channel amp I had and there was absolutely no noise when hooked up. I've tried everything. Moved power cable away from signal cables. Tried 4 different ground spots. Bought different rca's. Grounded head unit with amp. Please help!!!
Take head unit out and throw in garbage. Buy a new head unit that is not Pioneer and this will solve the problem. That or do a search for pioneer and alternator noise and do some reading to find and understand the solution.
me too. I'm getting kinda irritated because I've put in like 6 hours of trouble shooting just for the hiss.
i have hiss in my comps and i just cant figure it out as well.. thought maybe it was the headunit ground and tried grounding right to the battery but solved nothing. all other things i have tried havent worked either it pisses me off
I know its not the amp. I hooked 3 different 4 channel amps up without success. I hooked a 2 channel up and it worked fine. No matter which rcas I use if I only hook 2 two of them up the speakers won't whine. I am confused. Never had this problem before.
Also if I play my Ipod through my amp my speakers don't whine. I've also tried grounding my head unit rcas with no success.
coleg
coleg
ga
coleg
vegang
vegang
