no sound
frogcase2002
i went out to my car and there was no sound, a have a sony cd player, clarion eq and eclipes 4 chan amp, worked fine earlyer today but now dosnt, if i turn the volume all the way up i can hear music a tiny bit and it sounds all staticy, let me no if anyone knows whats wrong,,,,,,,
i checked the speaker wires going to the amp and they seem fine, all conected good, i moved around all wires and rcas and there was no kind of change to the sound
It's possible the radio is still sending out a small amount of voltage on the RCA's, I wouldn't think they would fail at the same time, but if the radio only had one set of preouts I could see it happening.
it has front, back and sub preoutput on the back of the cd player, iv always had it to the front preoutput to the eq, i just tryed to hook it to the back and sub output and it does the same thing
Straight to the battery your probably, just make sure it's clean and tight on there. Do what the previous poster said and run an ipod/mp3 player whatever right in to the inputs on the amp and see what happens.
Set your meter to AC voltage, disconnect the speaker wire leads while leaving the RCA's plugged in. Play something on the CD player and put your leads for your DMM on the speaker wire terminals. It should show changing AC voltage. I would also try just running the RCA's straight to the amp and bypass the EQ all together.
frogcase2002
frogcase2002
hamilton, ohio
frogcase2002
vegang
vegang
