No sound out of subs after awhile
Baby-d3005
I have 2 Kicker L7 and 1200 watt sony explode amp...after awhile when turned pretty high...no sound will come out of the subs but amp light stays on like it has power... i was wondering if it was a drop in voltage, but i have an optma red top battery also... and if a capacitor would do the trick to supply the power needed..
Baby~D
After about 2 to 3 minutes on a pretty high volume the no sound will come out of the subs but the power light on the amp stays on...after a few seconds, sound comes out of the subs again for about 3 seconds and kicks back off and so on and so on... but if i leave it around half way it will stay on all the time...
I ended up buying a 1.0 farad capicator but that didnt work either...so pretty much i have 80 dollar pretty lights from the capicator glowing in the back and thats all...
Baby-D
probably your gain. try setting it with a dmm. if thats not it make sure the amp has plenty of room to breath.
also what ga is your ground and power???
i have 4 gauge power and ground wire.....what is a dmm...right now i think that the amp is gettin hot and cutting off becuase the cooler it is the the longer it will go... i have it mounted on the back of my sub box with the seats down...what can i do if the amp is gettin to hot....if i cant fix it soon then i think im going to sell the amp and go ahead and get another amp....//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
Baby-d3005
Baby-d3005
Blufield, WV
Baby-d3005
