no sound out of front two speakers...
alexofak
but only when playing cd's.
So i went ahead and slapped a new deck into my truck the other day, listened to a cd and my sub and rear speakers were not working. I figured it was a connection i fudged or something i would deal with later when the dash was apart again. then i turn on the radio and everything kicks in; the sub and the rear speakers. i figure it is not a wiring issue. the deck is fairly old and has been in a shop for a few years, its a panasonic cq-c8100u.
I searched but all i found were people who had the fade or balance all to one side or had wired it improperly. I know the fade and balance is all set properly, and i dont think it is a wiring issue. any input would help, thanks.
You have your amp remote turn on wire attached to the antenna power wire on the HU. They are both blue, but one usually has a white stripe. Use the other blue wire for the remote turn on and it will work with CDs.
that would be my first guess too. try this op.
so, just to be clear the head has a blue wire and blue/white wire. should I put both wires from the head into the antennae wire and join all three or severe the current connection: blue(truck) to blue(head) and replace with blue(truck) to blue/white(head)? let me know if any of this is unclear and i will try to rephrase. thanks again.
alexofak
alexofak
Alaska
loopkiller
