no sound from speakers!
broncolaxman307
Broncolaxman307
I hooked up two 10 inch subs and 1200 watt amp in my truck. I tested them to make sure they worked by connecting the remote wire directly to my battery temporarily. Everything worked fine. Then I tried to connect my remote wire to the back of my head unit, but this would not power my amp. So i spliced into the blue/white wire in the back and connected that to my remote wire, but still got no power to my amp. I spliced into the red wire in my wire harness running from my battery and connected that to my remote wire. This finally powered my amp, but when I turned my head unit on, it would play the CD, but no sound came out of any speakers. I un-hooked the subs from the head unit and tried it again and still no sound out of my cd player. I disconnected my battery and checked my fuses. Does anyone know why I am still not getting any sound?
Thanks,
Aaron
so are you saying.. when you hooked up the remote out to the HU it wouldnt turn on but if you connected it directly to a 12v source it would?
and when it did turn on , there was sound from the speakers?
What head unit do you have. My Eclipse will not play if you use the antenna wire as a REM wire //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yea when i hooked up my remote out to my head unit from my amp, I didn't get any power to my amp. But hooking the remote out directly to the battery would run my amp and subs fine.
na i only have a 12oo watt amp hooked up for my subs. I drive a 1995 Ford Bronco, so there might be a stock amp somewhere. but other than that i dont have any other amps hooked up.
hmm i'd suggest maybe you pulled a speaker wire loose but if they both dont work and the HU tuns on.. then probaly not.. sue you werent messing with the fader or anything when trying to get the subs to work ? lol sorry man wish i could help ya more..
broncolaxman307
Broncolaxman307
broncolaxman307
Raleigh, NC
edzy
BP1Fanatic
BP1Fanatic
