CampNowhere
I have a 2010 F150 XLT and I installed a Kenwood DDX9703S with idatalink ADS-MRR with a idatalink FO1 harness. My Kenwood has been updated to firmware version 2.6.0008.0600. Here is a link to the wiring diagram I used for my connections, my vehicle starts on page 58, http://images.idatalink.com/corporate/Content/Manuals/RR-FOR/ADS-RR(SR)-FOR01-DS2TH-IG-EN_20151214.pdf
I am having 2 issues so far with this setup, the first is the most important.
1) I followed their wiring diagram and connected all wires together but when I started up my unit it gave me an error that said "There is an error in the speaker wiring. Please check the connection". This has been driving me crazy this weekend. There are only 8 wires that need to be connected from the Kenwood harness to the idatalink FO1 harness for audio, they are: white, white/black, gray, gray/black, purple, purple/black, green, green/black. They are all connected properly, white to white, green to green, etc... I connected the Kenwood harness to the DDX9703S and connected the small black idatalink cable from the ADS MRR to the idatalink port on the back of the DDX9703S and plugged the cable from the ADS MRR with the 3.5mm connector to the I/F port right next to the idatalink port on the DDX9703S.
There are 4 rca connectors on the FO1 harness, SUB IN/CENTER IN/AUX that I originally didn't have connected to my DDX9703S. The idatalink instructions said to connect the SUB IN & CENTER IN so I connected the SUB IN & CENTER IN to the SW port on the back of my head unit and still don't have audio. I also took all the RCA connectors and tried them in all ports just for laughs and still didn't get any audio.
2) SYNC command button on steering wheel doesn't appear to be working I believe. This may be related to the first issue since I can't hear sound so I am unable to tell if sync is actually working.
3) I purchased the SiriusXM SXV300V1 to retain Sirius, when disconnecting my factory headunit there was only 1 antenna connector, not 1 for the radio and 1 for sirius so I was unable to actually use the SiriusXM SXV300V1 because my antenna doesn't fit into the SiriusXM SXV300V1. If I purchase the SAT1 adapter from idatalink which would allow me to plug my antenna into the SiriusXM SXV300V1 which plugs into the back of the Kenwood, would it give me both siruis and radio even though the antenna isn't technically connected to the antenna connector on the Kenwood?
I know my other connections are working because I am getting vehicle info such as mph, tire pressure, VIN, etc... and the Kenwood can read the ADS MRR serial number and is communicating with it.
Sorry for the long post but this is driving me crazy and I'd appreciate any help I could get for this.
