no high output alt solution?
Xjeff
Hello I have a 2006 dodge stratus and I've looked high and low for a high output alt for it, all the known good brands that make them don't make one for my car style. Is there a away to get juice for my amps? I'm currently running a 1500 rms mini d block for my sub and a a/b 600 rms amp for my fronts. I have dimming lights like a strobe light when I'm at high volumes. Is it possible to run mulitiple stock alts I believe they're only 85 amps. I also have a xs power battery in the front not sure of the model installed a couple of years ago. I want to stay away from caps of possible. Any advice would be helpiful even if it's "you're screwed". Thanks!
well i had my through explanation deleted so ill keep it short. your car has a small case hairpin. they arent great at idle with a small pulley ratio and low idle speeds. thats why the higher amperage alt you get, the further the power curve is shifted thus you lose idle given same rotor speed. a healthy compormise for idle to output is a 240A small case alternator.
Xjeff
Xjeff
The dalles
Massive spl
