No Fuse on Aftermarket Wiring Harness???
jrut224
I have an Alpine CDA-9831 head-unit, and unfortunately lost the original wiring harness when I removed it from my last vehicle. I purchased a new harness (http://www.sonicelectronix.com/item_4265_Alpine+16+PIN+Head+Unit+Replacement+Wiring+Harness.html ), but it did not have the fuse setup on the battery-power wire like the original did.
I assume I need this? I don't understand why it wouldn't be included with the aftermarket...
Alpine describes it as a "choke coil w/ fuse holder (10A )" ... would a 10A inline fuse work if I picked one up from the hardware store, or does the choke coil do something more than just protect against a jolt?
Any suggestions???
Thanks in Advance
Or rather, is this essentially what I need?...
PAC CSS-100 (css100) - Noise Filters - Sonic Electronix
I found that the choke coil cuts out noise from the vehicle power.
If this is infact what I need, would I still need a 10-amp fuse holder like I mentioned before? (I know that my original harness had a 10A fuse, but I can't tell if this noise filter has a fuse setup included, or rather if it is just for 10-amp system.
jrut224
jrut224
Maryland
jrut224
