No audio from radio
I know its not the radio I thought it was so I replaced it and it's still doin the same thing I took the driver door panel off and the door tweeter was broke n just hanging by the harness so I disconnected it and it and it worked fine them I installed my subs and it started doing it again
When does it work? Does it work when you're on radio input, but not on others? If so, you have you need to connect your remote wire where your antenna wire is connected to get the OEM amplifier integrated and turning on.
Bassmaniac
Bassmaniac
Baltimore ,md
nismos14
