Nitrous in! pix and vids
I would like to say I bet you a MILLION dollars with the Jmod, I would WALK ALL OVER you id they ahd 5 speed's. Hand down no problem! I had a automatic GT before I got my 5 speed and it is night and day.
You can not leave as hard as I can. And even with Gears or a tune, you are not going to be shifting as high as I would.
I am not doubting your car, but I know what that car will run. I have more Mod motor shit than you have ever seen! I mentioned earlier in the thread, that if you needed anything to let me know.
But the more I read the more I laugh.
Just to let you know I have
07 Apearance Package gt500 Black and red
JLt cold air intake
Metco Pulley
And A tune.
And I hold the record for the fastest Gt500 on stock tires.
If you doubt me ask around corral Forums or get on you tube. 11.47 @ 121 going sideways.
Also have the Old TDC car
96 Gt with 66MM turbo, PA supercomp c-4. And a ton more!
And a all stock 07 GT.
So before saying shit think...It might be a carAudio forum, but that does not mean we do not know about car's.
If you do not believe me I will take some pics for you!
Liek I said before if you need any help ask me, or need any parts ask me. I can get anything you can for alot cheaper. PM me if you need shit.
ANd by no way am I bragging! Because I am paying out the *** for what I have! I am just trying to prove a point.
Kthanks bye.
So what point were you trying to prove? I still think autos are better for the drag strip. If you have a gt500, then ofcourse you will kill me, auto, or not. I have a crownvic, bragging about being able to beat me in a shelby isnt saying much at all. 500hp supercharged 5.4 vs 300+ hp vic... With some work, on my stock block, just with nitrous and boltons, it can dip into the 12s nicely, as I have a buddy that has done a 12.7 with nos without going into the engine. I wouldnt mess with a gt500, i know my cars limits.. anyways
I would really like to have this n/a engine, but it is a hefty price.
http://www.seanhylandmotorsport.com/modular_crate_engines.shtml
Here ya go sweetheart, I'll put money this little 4 cyl. will take down that nitrous fed v8 any day of the week, oh yeah it's a 6 speed as well. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Stage-2, 2.5L Short Block;
-(4340) I-Beam Rods
-Forged Pistons (8.5:1)
-Chromoly Pins
-Low Friction Pins
-Computer Balanced
-Forged Crank
-Cosworth Piston Coating: Antifriction Side and Thermal Barrier Top.
-Cosworth Coated: Main bearing upgrade.
-Cosworth Stage-2 Race Cams
-Heads (313 CFM @ .45 lift)
-Cosworth CNC Ported heads:EJ25
-Double springs (10K+RPM),
-1.5mm over sized intake valves
-1.0mm over sized exhaust valves
-Ported TGV
-Cosworth 14mm head studs
-Custom built 4"to 3.5 turbo back exhaust
-custom built up-pipe
-Equal length headers
-Garrett GT4088R
-Twin Tial 44mm wastegate
-Tial BOV
-10AN Aeromotive FPR fuel system
-1250cc top feed low impedance fuel injectors
-Fuel Rails
-PPG Dogbox w/ straight cut gears
-Hydra EMS tuned on 109 unleaded (Tuned by Junior)
-2600lbs w/ driver
-109 unleaded at @31psi dyno:
All of that money, work and only in the 11's? lmfao...
626.7?? Thats on a chassis dyno, Id assume??? And in a 2600# car and ALL YOU COULD DO IS MID TO HIGH 11's!?! Id be UBER pissed at those time slips, and would not post them anywhere!
Why, may I ask does the dyno sheet say GT40?
I believe that's the model turbo
I'm spraying too. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The shits fun //content.invisioncic.com/y282845/emoticons/highhorse.gif.6bbb570c3f53dc0dcce8a2b8ad05cf11.gif
i think a real challenge would to get my 1982 mercedes 4cyl diesel to get 100hp it only has 67 right now //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
AND IT HAS 4 GEARS!
-(4340) I-Beam Rods
-Chromoly Pins
-Low Friction Pins
-Computer Balanced
-Forged Crank
-Ported TGV
-Garrett GT4088R
-Tial BOV
-Fuel Rails
-2600lbs w/ driver
i really hope you spin tires all the way down that track an thats why your times are so low for all that work. and the turbo civic with a riced out kid and ugly as **** wheels clames to be as fast as you... thats sad but what do i know my jetta runs a 13.9 and how i did that idk.
yeah maybe not thats an awd car whats he suppose to spin dumbass.nice ride but i think something is wrong with the driver at 31psi you should be running and trapping faster with higher speeds
Towncar
Towncar
who knows
cvjp417
michigan born
    May 14, 2026
michigan born
    May 14, 2026
