NINe5 came in: (pics of interals)
N!ggaz! I solved it! turns out you have to turn on on-board LPF Xover for it to function along with the remote on switch. Which is IMO silly and makes that remote switch absolutely pointless if I have to turn on on-board xover anyways for it to work even if im active.
so i am turning on that xover and setting the frequency just to the highest it can, since im active signal will Xovered regardless when it hits amp.
id sell my nine5 in a heart beat //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I might sell my old RF's & Cadence for it. But he is working on the SAE line and a large 2 channel and possible an amp between the 1500D and 3000D. So for now it is just a wish.
werd, and amp with ED high powered 4 channels, and the Memphis Belle sub output will make the best 5 channel amp.
but if the ed does put out 900rms @ 1 ohm, then its not that bad from the belle which is 1100rms @ 1 ohm.
if SD can do 1500rms @ 1 ohm and 150x4 @ 4 ohms, then that will be the amp to have.
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
DejaWiz
