NINE.1 or sae-1200
loud-n-low
i give ladies 30mm xmax
I ordered the nine.1, however i can cancel it. both claim 1200 watts @ 12 volts. is it safe to say both amps will do 1400-1500 at 14 volts? aslo noticed the 9.1 has 120 amps of fuses, the Sundown has 150 amps worth. Sundown more powerful? Thanks!
Performance both by the amplifier and the company should make this an easy decision. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have read many threads where pople state that the nine.1 does over rated power, however they do not care for the company. how does Sundowns sae line differ from the saz?
sundown has better CS then ED and i dont think that 9.1 will do 1500...i know the sundown will //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The 9.1 will do over 1500w at 14.4 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
what are the biggest differences between the sundown saz-1500 and the sae-1200
i was told from db-r the 1200 will do more power around 2 ohm than a 1500 would. 1500 is good for 1 ohm. i was actually told by db-r to wire to .5 ohm on my 1500 because after rise i will be near 1 ohm. and thats where that amp like to be. 1200 does not work as well under 1 ohm
so the sae-1200 isnt good to run at one ohm to get the 1500 watts at 14 volts?
loud-n-low
loud-n-low
upstate NY
loud-n-low
