NIB JL Audio 500/5 Amp + RBC-1 Remote Bass Knob
  • 2
Levictus
JL Audio 500/5 Amp brand new in box. It has only been out of its box for photos and initially to check condition after shipping. It has never been mounted, powered, or connected in any way. I bought this amp a while back for a diy car audio project that got put on hold when I got married and then had kids. It's been sitting under my bed for years. I finally found the heart to part with it which I'm sure I will regret years from now. I will include the JL Audio RBC-1 knob still in packaging as a bonus (sells for about $30). This amp will run your whole system!
JL Audio 500/5 5 Channel Car Audio Amplifier
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
1-year SonicElectronix.com warranty
Pictures are of actual products. In original box/packaging with manual and Allen key.
This amp sells between 350-400 in good used condition. The only new one I have seen is $525 + shipping. I am also including the RBC-1 remote bass control knob which directly interfaces with the amp. They sell for about $30.
Asking $475
Standard shipping included in price, PayPal only, to a verified US PayPal address only. Items are sold as is and no warranty of any kind is expressed or implied. Let me know if you have any questions. I apologize, I have no sales or feedback with the iTrader system as I have never sold anything here or through that system before. I just joined the forum today specifically to post this as my local car audio shop thought it would be a better idea than craigslist or ebay. Hopefully you will find paypal offers enough protection for items purchased through them.
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Levictus
Levictus
Raleigh, NC
Levictus
    May 24, 2024
