next install help (LOUD STEETBANGER)
Matt A
i have 2 audioque hdc3 15s and and audioque 3500d in a custom ported box in my envoy.... i have all the electrical work needed to run about 7000 some watts of power (250 amp alt, 3 redtop optimas, an interstate megaton, and 0 gauge throughout)..... plain and simple.... what should i do from here to make my envoy an unbearably loud streetbanger?....im also trying to be very efficient at the same time...i wanna spend under $2000 for everything to be installed and finished....thank you
You'll never put out 7000 watts with that electrical fyi.
You already have plenty of equipment. I wouldn't do anything different other than build a nice box.... but what should I tune it to you might ask. Well are you going for hairtricks or numbers on the meter? You can't really have both unless you step your equipment up a lot. If you want hairtricks, tune to 30-33hz. If you want loud on the meter, tune just below your vehicle's resonant frequency. Set your subsonic right at this frequency and never play music. Since you said streetbanger, tune low. Do some hairtricks and never tell anyone you're hitting 150 because you'll probably be JUST shy of it. BUT high 140's at 35hz will make about anyone want out. It's all in the box at this point.
Matt A
Matt A
Youngstown, Ohio
mlstrass
