used white phosphorus against the iraqi people which is a chemical weapon. So knowing this if he gave the order to use chemical weapons on us he's no worse than us.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
oh please, white phosphorus?! Thats an incandescent. you could give the chemical formula for gun powder and say its a "chemical weapon"
"How sulfur mustard (mustard gas) works
Adverse health effects caused by sulfur mustard depend on the amount people are exposed to, the route of exposure, and the length of time that people are exposed.
Sulfur mustard is a powerful irritant and blistering agent that damages the skin, eyes, and respiratory (breathing) tract.
It damages DNA, a vital component of cells in the body.
Sulfur mustard vapor is heavier than air, so it will settle in low-lying areas. "
"How sarin works
The extent of poisoning caused by sarin depends on the amount of sarin to which a person was exposed, how the person was exposed, and the length of time of the exposure.
Symptoms will appear within a few seconds after exposure to the vapor form of sarin and within a few minutes up to 18 hours after exposure to the liquid form.
All the nerve agents cause their toxic effects by preventing the proper operation of the chemical that acts as the body’s “off switch” for glands and muscles. Without an “off switch,” the glands and muscles are constantly being stimulated. They may tire and no longer be able to sustain breathing function.
Sarin is the most volatile of the nerve agents, which means that it can easily and quickly evaporate from a liquid into a vapor and spread into the environment. People can be exposed to the vapor even if they do not come in contact with the liquid form of sarin.
Because it evaporates so quickly, sarin presents an immediate but short-lived threat"
Those are WMD's my friend.
Here is white phosphorus:
"What is white phosphorus?
White phosphorus is a colorless, white, or yellow waxy solid with a garlic-like odor. It does not occur naturally, but is manufactured from phosphate rocks.
White phosphorus reacts rapidly with oxygen, easily catching fire at temperatures 10 to 15 degrees above room temperature.
White phosphorus is used by the military in various types of ammunition, and to produce smoke for concealing troop movements and identifying targets.
It is also used by industry to produce phosphoric acid and other chemicals for use in fertilizers, food additives, and cleaning compounds. Small amounts of white phosphorus were used in the past in pesticides and fireworks."
taken from cdc.gov
please do your reading before claiming the US is as guility as saddam //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
