Newb question.....
  • 5
Your amp will produce 900 watts when presented with a 1 Ohm load. Regardless of how that 1 Ohm load is achieved the amp still outputs the same 900 watts. No matter whether it is a single DVC 2 Ohm driver or four SVC 4 Ohm drivers or a pair of DVC 4 Ohm drivers......the output remains 900 watts.
So - if you have two subs connected showing it a 1 Ohm load (which results in a 900 watt output according to the info you have provided) then that 900 watts is split between the two subs, or 450 apiece.
i think he gets that, i think he just wasnt sure if he was going to get a 1 ohm load.
Well, considering this was the pertinent part of his original post:
The amp is rated at 900w rms @ 1 ohm. My question is do the subs see 900 watts each or will it be split it in half?
I was simply answering what was asked as you apparently were unwilling to.
OMFG... ur avatar is sick. thats not in a good way.
Yes, you really need to remove that man....not cool!!! It's beyond sick...and you will not make any friends here with it. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Thanks Bri , thats what I was looking for.
Better? lol //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Thanks All
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
523
92statetrooper
92statetrooper
Inman, SC
92statetrooper
    May 16, 2024
    May 16, 2024
